Магазин "Килогерц" - Автозвук (kHz.com.ua)
На страницу Пред.  1, 2, 3, 4, 5, 6, 7, 8, 9, 10  След.
Начать новую тему   Ответить на тему    Список форумов Український клуб фанів FIAT / CLUB UCRAINO TIFOSO DELLA FIAT -> Автозвук
ЙОЖЕГ
СообщениеДобавлено: Ср Мар 18, 2015 16:57    Заголовок сообщения: Ответить с цитатой
Цікаво дізнатися вартість корпуса для сабіка, ЗЯ, максимально малого об'єму. Саб ось такий: Monacor Carpower BlackBass-10
Параметри з сайту виробника:
BLACKBASS - this does not merely describe the appearance of these new top-class subwoofers from CARPOWER. They provide a powerful and at the same time a very clear bass reproduction of low fundamental resonance up to the threshold of pain. In this price class, both the mechanical stability and the sound set standards.
High-power subwoofer, 2 x 250WMAX, 2 x 4Ω
The 25cm version of this bass speaker with carbon fibre cone also provides a powerful reproduction. High power capability, long excursion, perfect stability, and high quality materials applied at this speaker like special rubber surround and the extended CARPOWER full air circuit cooling of the drive system with rear ventilated spider, drilled pole core AND air gap provide an amazingly clear sound at every application. This 2 x 4Ω bass speaker with dual voice coil provides a bass reproduction of low fundamental resonance in bass-reflex cabinets of about 45 litres, real enjoyment also possible with closed cabinets, approx. 25 litres only.
Impedance (Z) 2 x 4Ω
Resonant frequency (fs) 32Hz
Max. frequency range f3-300Hz
Music power 2 x 250WMAX
Power rating (P) 2 x 175WRMS
SPL (1W/1m) 86dB
Suspension compl. (Cms) 0.19mm/N
Moving mass (Mms) 130g
Mech. Q factor (Qms) 7.2
Electr. Q factor (Qes) 0.46
Total Q factor (Qts) 0.43
Equivalent volume (Vas) 30 l
DC resistance (Re) 2 x 3.6/1 x 1.8Ω
Force factor (BxL) 10.5Tm
Voice coil induct. (Le) 2 x 0.7mH
Voice coil diameter 50mm
Voice coil former aluminium
Linear excursion (XMAX) ±15mm
Eff. cone area (Sd) 325cm2
Magnet weight 90oz.
Weight 5kg
Йожег сцуко лічнасть!
Brend
Авто: Fiat Tipo 1.4 -> Alfa Romeo 156 1.8TS -> Honda Civic VI Coupe 1.6 Turbo -> Honda Accord 5 Coupe 2.2
СообщениеДобавлено: Ср Мар 18, 2015 17:00    Заголовок сообщения: Ответить с цитатой
если кубик - то 800грн с двойной передней стенкой, из фанеры 18мм, перетянут карпетом и с терминалом для подключения.
Если со скошенной задней стенкой, то 1000
Магазин "Килогерц" - Автозвук и мультимедиа kHz.com.ua Кому звучка в машину? Обращайтесь!
(о44) 384-22-82, (о63) 384-10-10
ЙОЖЕГ
СообщениеДобавлено: Ср Мар 18, 2015 17:33    Заголовок сообщения: Ответить с цитатой
Краще, звісно, зі скошеною стінкою. А який розрахунковий об'єм буде? Фізичні розміри?
Brend
СообщениеДобавлено: Чт Мар 19, 2015 02:07    Заголовок сообщения: Ответить с цитатой
завтра посчитаю, а то это надо старый комп запускать)) только там програмулина идет.
Brend
СообщениеДобавлено: Чт Мар 19, 2015 13:52    Заголовок сообщения: Ответить с цитатой
сори, то фазик был, закрытый хочет 20,6 л жэто к примеру 30х30х30(15)см
StarsOn
Клубный казначей
Клубный казначей
СообщениеДобавлено: Пн Апр 13, 2015 20:22    Заголовок сообщения: Ответить с цитатой
Саш, привет.
Шумка и вибра, случайно, по хорошей цене не найдется? Rolling Eyes
ZFA17600000002578
Brend
СообщениеДобавлено: Пн Апр 13, 2015 20:42    Заголовок сообщения: Ответить с цитатой
StarsOn писал(а):
Саш, привет.
Привет. Ну тут б/ушки не бывает))) так что цена стандартная и клубням скидка. Посмотри "Стандарт" - цена/качество.
Буба
Авто: Пежо 806 Эксперт.
СообщениеДобавлено: Пн Апр 13, 2015 21:46    Заголовок сообщения: Ответить с цитатой
Старая сигналка накрылась не так давно......а на полке уже почти год пылится Scher-Khan Magicar 7 . По чем нинче установка сигнализации???
Brend
СообщениеДобавлено: Вт Апр 14, 2015 19:06    Заголовок сообщения: Ответить с цитатой
гривен 500, но мы пока не занимаемся сигналками, разве что поучится на тебе могу за пиво)), но пока до конца недели работа есть
Slavon
Авто: Была Регата -Осталась в клубе! Fiat Doblo Turbo! + Fiat Tempra 2.0 SW
СообщениеДобавлено: Чт Апр 16, 2015 20:40    Заголовок сообщения: Ответить с цитатой
Привет в кратце! У меня в Тмпре SW в торпеде стоят какието пионерчики, по звуку меня вполне! В штатных сзади стоял какойто хлам допотопный маде ин джермани ели прочитал выгоревшие буквы)! Заменил на двухполосные китайские динамы (подогнали на шару)мафон Pioneer 3050ub как он валит меня НУ ОЧЕНЬ устраивает до него был kenwood kdc w312 - отличный аппарат но без юсб! так мне бы вот совет- какие в штатнеые 13 кинуть динамы до 1500 грн чтобы качали норм басок или проще вырезать с зади в бочинах подиумы и кинуть 16,5 круглые динамы или овалы! (В добле у меня стоит панас магнитола а динамы туда взял Pioneer Ts-a170ci так они так валять качественно и чисто и бас просто ,,,здец что мне и саба ненадо!
Brend
СообщениеДобавлено: Чт Апр 16, 2015 21:39    Заголовок сообщения: Ответить с цитатой
Не совсем понял что у тебя там где))) знаю по типку, что в торпеде 10ки, в дверях вроде 13шки, но если не ошибаюсь, то 16 туда влезут с небольшими доработками. В общем я б посоветовал кинуть в двери нормальные динамики и обработать все правильно, ну если есть возможность, то овалы в заднюю полку лишними не будут, а про торпедо забыть. А лучше всего подьехать ко мне "на березки", думаю почти все форумчане знают где этоWink постоять, обкурить и посмотреть что там и как лучше. Вот
Slavon
СообщениеДобавлено: Чт Апр 16, 2015 22:33    Заголовок сообщения: Ответить с цитатой
В темпре универсале в дверях нет дюрок! Есть в торпеде 10-ки там у меня пионеры и штатные места над крыльями из нутри 13-ки там корочее типо как в жигулях 4-ке если видел! под самыми боковыми задними стеклами! Полки у меня небыло( гдето выброшена прошлыми владельцами!)
Brend
СообщениеДобавлено: Пт Апр 17, 2015 00:10    Заголовок сообщения: Ответить с цитатой
Ну не знаю, надо смотреть что там можно сделать. В идеале заезжай - разберемся, не, так думаю надо 13е компоненты брать, например hertz dsk130, от магнитолы будет огонь играть.
Den_sam
Авто: Fiat linea
СообщениеДобавлено: Вт Окт 27, 2015 01:06    Заголовок сообщения: Ответить с цитатой
Привет.
Хочу поменять на линии голову и динамики.
Посоветуйте, голову процесорный alpine или clarion акустику hertz, бюджет +- 5000/6000 грн
Brend
СообщениеДобавлено: Вт Окт 27, 2015 11:37    Заголовок сообщения: Ответить с цитатой
Den_sam писал(а):
Привет.
Привет. Из процессорных по сути есть только одна голова http://khz.com.ua/products/clarion-cz703e
Если бюджет ограничен такой суммой, то тут надо отказаться от процессоров, толку все равно не будет, взять что попроще, да чтоб чего то добиться в комплексе
Начать новую тему   Ответить на тему    Список форумов Український клуб фанів FIAT / CLUB UCRAINO TIFOSO DELLA FIAT -> Автозвук Часовой пояс: GMT + 3
Страница 9 из 10
Вы не можете скачивать файлы в этом форуме
